Cisco WOrks Eroor Urgent
I have LMS 2.5.1 installed it was working fine but now suddenly it is not displaying the LOGIN page i checked the windows services all are fine apart form the APACHE service it is not starting & when i try to restart it is doest i also rebooted the server but still it is the same
Thanks in advance
CiscoWorks ANI database engine : Manual
CiscoWorks Daemon Manager : Automatic
CiscoWorks RME NG database engine : Manual
CiscoWorks Tomcat Servlet Engine : Manual
CiscoWorks VisiBroker Smart Agent : Manual
CiscoWorks Web Server : Manual (but not starting)
CWCS Cmf database engine : Manual
CWCS rsh/rcp service : Automatic
CWCS syslog service : Automatic
CWCS tftp service : Automatic
DFM dfmEpm database engine : Manual
DFM dfmInv database engine : Manual
DFM dfmFh database engine : Manual
IPM Aging Server : Automatic
IPM DB Server : Automatic
IPM Naming Server : Automatic
IPM PM Server : Automatic
IPM Stopper : Automatic
Mayur
1 ACCEPTED SOLUTION
Re: Cisco WOrks Eroor Urgent
You may have a DLL conflict. Check for multiple versions of ssleay32.dll and libeay32.dll on the system. If you have more than one of each, make sure the ones in the CiscoWorks patch (NMSROOT\bin) are found FIRST in your PATH environment variable.
If you run the command pdshow from the command line are any of the key processes down? Are you accessing via hostname or IP address? Also, are you using SSL?
Silver
Common reason for apache not starting is that port 80 is in use.
This can be caused by somefunnydude activating IIS os another webserver.
Cheers,
Michel
Thanks This was the problem
115
