Cisco Works LMS Demo Doesn't WORK
After the installation the Apache web server does not start.
After running a resetcasuser.exe and recreating the server certificates, Apache is still down.
pdshow:
Process= Tomcat
State = Program started - No mgt msgs received
Pid = 3144
RC = 0
Signo = 0
Start = 5/19/2009 1:36:33 PM
Stop = Not applicable
Core = Not applicable
Info = Application started by administrator request.
Process= TomcatMonitor
State = Running normally
Pid = 3604
RC = 0
Signo = 0
Start = 5/19/2009 1:36:37 PM
Info = Tomcat Server up
Process= Apache
State = Never started
Pid = 0
RC = 0
Signo = 0
Start = N/A
Info = Not applicable,
C:\PROGRA~1\CSCOpx\MDC\Apache>Apache.exe -t -d .
c:/program files/cscopx/mdc/apache/conf/httpd.conf: Syntax OK
Most of the Apache logs are empty and the error.log shows these errors:
[Tue May 19 13:38:07 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 13:48:52 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 13:57:09 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 14:05:30 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 14:11:45 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 15:15:26 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 15:30:23 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
[Tue May 19 15:41:45 2009] [crit] (2)No such file or directory: make_sock: could not bind to port 443
The server services set to automatic are the daemon manager and CWCS rsh/rcp service :Auto
CWCS syslog service :Auto
CWCS tftp service :Auto the rest are set to manual.
The installation logs do not show any errors.
Please advise as soon as possible.
Thanks.
1 REPLY
Re: Cisco Works LMS Demo Doesn't WORK
You have another service (most likely IIS) bound to TCP port 443. If you do not need that other service, disable it. If you need to leave it enabled, you can change the LMS SSL port number using the command NMSROOT\MDC\Apache\changeport.exe PORT -s. for example:
changeport 1755 -s
203
