Cisco WOrks supported OS
I have a customer that would like to use Windows 2003 R2 Server, for a cisco works server.
In the prereq.pdf (attached) for cisco works only the following 2003 OS are supprted.
Windows 2003 Server (Standard Edition) with Service Pack 1
Windows 2003 Server (Standard and Enterprise Edition)
Does anybody know if the R2 release is supported?
Cheers
2 ACCEPTED SOLUTIONS
Re: Cisco WOrks supported OS
Currently the only supported OS's are the ones in the release notes that you list above:
With version 2.6 you can run Windows 2003 R2 Server Standard and Enterprise Editions. See link below for more info.
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_qanda_item0900aecd80532fc7.shtml
R2 is now supported in LMS 2.6 which was posted to Cisco.com yesterday. See http://www.cisco.com/cgi-bin/tablebuild.pl/lms26 .
Red
How about D2?
Bronze
Is Windows server 2003 R2 with Service Pack 1 supported for LMS 2.6 ??? note: "with SR1"
Many thanks for your response.
I should have put in the original question that we are using CiscoWorks Small Network Management Solution v.1.5.
Cheers again
Windows 2003 R2 is not supported with SNMS 1.5.1.
166
