10-23-2010 03:03 AM
Hi.
We have trouble with getting config for certain devices. A manual job works fine, but the schedule job does not.
Devices are neither in the success list nor in the failed list.
I've checked the device credentials.
syslog triggered config fetch works only for one of the devices.
BR
Bjornarsb
10-23-2010 10:49 PM
What version of RME do you have? What types of devices are you managing in LMS?
10-24-2010 02:31 AM
Version : 4.0.6
Problems are related to twenty WS-C3560G-48PS-S switches.
10-24-2010 09:59 AM
Are these the only devices you have in RME? If you go to RME > Config Mgmt > Archive Mgmt > Sync Archive and run a job for all devices in RME, does that job succeed?
10-24-2010 10:50 PM
Yes a manual job of the problem devices works fine. We have approximately
500 devices in total.
10-24-2010 11:03 PM
Post the log file from the directory pertaining to the system collection job (this should be under NMSROOT/files/rme/jobs/dcma/ArchiveMgmt).
10-25-2010 12:47 AM
10-25-2010 10:26 PM
I'm not seeing any problem in this log file other than the fact that your server is not localized for US English. According to the log, all 399 devices complete in about 51 minutes. What are you seeing in the GUI that indicates this job is encountering a problem?
10-26-2010 01:18 AM
Thanks for your help so far.
The problem is quit strange. A manual job works fine, but the scheduled job
says nothing about the 20 new switches.
The 20 switches seems to not be in the total list for some reason.
I.e. the gui says nothing about the new devices, neither failed or success.
br
Bjornarsb
10-26-2010 11:29 PM
Is LMS integrated with ACS? Is this configuration job the system job created under RME > Admin > Config Mgmt > Collection Settings or one you created manually, then scheduled to run periodically?
10-28-2010 02:48 AM
Config Collection is enabled under RME > Admin > Config Mgmt > Collection
Settings
10-28-2010 11:16 PM
Is that the job that is not working as desired? Is LMS integrated with ACS?
10-28-2010 11:45 PM
Yes, that is the job that is not working as desired?
LMS is not integrated with ACS.
10-28-2010 11:58 PM
Try disabling the collection job. Disable it and save the new configuration. Leave the Collection Settings screen then come back to it. Re-enable the collection job, then see if the newly run job instance picks up the missing switches.
