Webcast-Catalyst9k
cisco works
hi!! i really new to cisco works......actually iw ant to know what that is and which version shd i get to configure my routers in network by using cisco works.....there are lot of cisco works software....which perticular i have to get inorder to configure my routers and switchesd......cheers
1 REPLY
Re: cisco works
There are a few options depending on your # of devices and budget.
LMS 2.5.1 is the latest version of Lan Management Solutions available and can handle a high number of devices and does various items including configuration management, software management, topology map, visual view of devices and more:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2425/index.html
For less devices you can look at SNMS:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2408/index.html
108
