06-05-2006 09:03 AM
n what screen in cisco works, can I set how often it archives my configs, and for how long I want to keep them. Right now it just seems to archive when there is a change made to the config. Thanks.
06-05-2006 10:54 AM
RME 4.X:
RME - Admin - Config Mgmt - Archive Mgmt
RME 3.5:
RME - Admin - Config Management - General Setup
06-05-2006 12:09 PM
where do I find the verison I'm running
06-05-2006 12:15 PM
RME 3.5 is what I'm running
06-05-2006 10:57 AM
That depends on the version you use.
In the latest under RME -> Administration -> Configuration Management, you will find it all.
Archive Settings
Collection Settings
Purge Settings
But the only good reason to archive is, because there was a change.
The default settings are quite alright
Cheers,
Michel
