CISCO7606-S Supported in LMS
Hi all,
After long wait for 6 months.
So far RME is supported, but CiscoView still dont have such package.
When its going to be supported ?
Posted by: jclarke - Customer Support Engineer, CISCO SYSTEMS, CCIE - Feb 24, 2008, 10:59am PST
Does this 6509-E have a vlan database, or are you doing all of your VLAN configuration in the running config? If the former, then you can ignore this message.
The 7606-S is not yet supported in LMS. Support is planned for April of this year.
DFM is the only application in LMS that does not respect the display name. Therefore, in order for hostnames to show up, you must have working DNS, or the devices must be in the server's hosts file.
  • Network Management
1 ACCEPTED SOLUTION
Re: CISCO7606-S Supported in LMS
The 7606-S is properly supported in the Cat6000IOS CiscoView package version 30.0.
Problem resolved. Thanks.
92
