CiscoView 6.1 askes SNMP credentials
thewolffman
We have LMS 2.5 and SP2. Now when i want to view a device with CiscoView 6.1 it askes for SNMP credentials. But these should be provided by the repository? Isn't it?
How can i fix this?
Jeroen
nhabib
Level 9
Level 9
You might be running into bug id CSCeh22258:
CiscoView challenges for credentials when only host names are in DCR
SYMPTOM:
CiscoView Challenges user for SNMP Credentials even when the device is successfuly
stored in DEVICE and CREDENTIALS in CS and is selected from the OBJECT SELECTOR
in CV.
CONDITIONS:
This will happen when the customer added devices using HOST NAME (not IP).
WORKAROUND:
Manually add an IP address in D & C for every device, and CV will not challenge.
Thanks!!
