CiscoView Add a package
I am trying to upgrade the CiscoWorks package for the cat6000. The available version is 8.0, the currently running version is 1.1. The package installer won't let me upgrade this due to a package incompatibility. Is there an interim version I need to upgrade to first? If so, how do I upgrade to this? The error I get is:
Following packages cannot be installed
Package Reason
Cat6000(8.0) major versions are incompatible.Required version 8.10 for Cat6000 package
Re: CiscoView Add a package
Which version of CiscoView are you trying to add the package for?
You can try this to see if you can get it installed:
1. Remove the old CatQDm package (if there)
2. Remove the previous package version of Cat6000.
3. Download the new device package and the dependent files ( CatQdm,CLIParser,SwitchAddlets and Entity)
4. Install the dependents ( switch addlets, entity and cliparser )
5. Install new Cat6000 device package
6. Install new CatQdm package
That fixed it. Thanks.
108
