Ciscoview CSCsg55089 demands 6.1.6
When i try to upgrade my LMS 2.6 for cisco view 6.1.5 and Common Services 3.0.5. It says no updates available.
How can I obtain Ciscoview 6.1.6 to have this bug fixed?
or can there be any patch upgrade if 6.1.6 comes only with LMS 3.0
Re: Ciscoview CSCsg55089 demands 6.1.6
CV 6.1.6 comes with LMS 3.0 and you will need to upgrade to 3.0 to get this version.
Thanx for your response. After looking for other possible causes of the issue faced, i came across CSCsf96866.
Now this one again requires Common Services 3.0.6 and its not available through software update tab.
Is this also part of LMS 3.0.
Common Services 3.0.6 is a free update on top of LMS 2.6. You should be able to download it from Common Services > Software Center > Software Update. It can also be found on Cisco.com at http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des .
118
