CiscoView Error
I have a problem accessing some devices on Ciscoview. I get this error.
Message: Can't find applicable device package for 172.21.203.2.
Cause: Device package for this device type is not installed or device support for this device type might not be available or you are attempting to open a component inside a device.
Action: Please install a device package for the device type or open the parent device to manage the component.
Kindly assist me in resolving this.
Re: CiscoView Error
Go to Common Services > Software Center > Device Update check CiscoViewand download the latest device packages from CCO. If it is a new device model it may still not be supported.
If the before mentioned update does not help, please provide the sysObjectID of the device.
Re: CiscoView Error
Thanks. I will do it, will get back if it doesn't work.
Re: CiscoView Error
cisco 1801 router 1.3.6.1.4.1.9.1.638 is not working with ciscoview 6.1.7 (lms 3.1)
I went to CS-> device packages update , installed rtr1800, installed it and restarted dmtgd but still can t see my device over ciscoview ...it shows me the same error as above (previous post). It is working fine for all my access-point AP1242AG
any ideay or any log file i could check why exactly it s failing.
107
