Webcast-Catalyst9k
Ciscoview issue
We're running LMS 3.2.
I'm getting the following error message when I try to view some switch/router types in Ciscoview;
Error in file: '/CVng/dynapi/src/dynapi.js'.
Line number: 136.
Message: Permission denied to access property 'lyrobj' from a non-chrome contex
sam
1 ACCEPTED SOLUTION
Re: Ciscoview issue
This browser is not supported. Try with Firefox 3.0.14, and see if you get the same error.
Re: Ciscoview issue
What browser and what browser version are you using?
Re: Ciscoview issue
I'm using Firefox v3.5.3.
Re: Ciscoview issue
Re: Ciscoview issue
I've downgraded Firefox to v3.0.14 and the problem is now solved.
Thanks a lot jclarke!
248
