CiscoView1.6.1+1800Rtr
Hi all,
I have installed LMS 3.0 included CV 6.1.6 but it doesn't work with 1841 router.trying to install Rtr1800.cv50.v6-0 and v5-0.. Other devices view ok.
thanks in advance
1 REPLY
Re: CiscoView1.6.1+1800Rtr
Yes, the 1841 is supported in Rtr1800 6.0. Check NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw/ and compare the list of contents to NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs . The directory contents with regard to .zip files should be the same in both locations. You should have an RTr1800.zip file in both locations.
111
