12-28-2007 06:38 AM
getting below error
CM0056 Config fetch failed for ATL-6506-1-2 Cause: CM0204 Could not create DeviceContext for 249 Cause: CM0206
Please help
01-01-2008 08:46 PM
You have not included the entire logs for which Dave asked. There is nothing we can get from these fragments.
01-01-2008 09:02 PM
01-01-2008 09:03 PM
correction software installation is not allowed
01-01-2008 09:13 PM
Please provide the list of contents in NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs and NMSROOT/classpath/com/cisco/nm/xms/psu/pkgs/rme.
01-01-2008 09:44 PM
01-01-2008 09:56 PM
Your lib/pkgs directory is missing the Cat6000.zip package. This package is critical for config archive to work on this 6506. You can copy this file from the pkgs/rme directory, then restart dmgtd, and the config archive problem should be fixed.
01-01-2008 10:00 PM
Oh WOW, thats great news for me, i should be doing right away and will share the result with you. thanks a bunch dude.
01-01-2008 10:38 PM
Jclarke, Amazing, my issue is resolved now. thanks a million you amde my day buddy.
01-02-2008 12:05 AM
One last query on this Dude, wher can i get or download WAAS package to addit in Pkgs folder. thanks again.
01-02-2008 09:16 AM
There is no WAAS package. The WAE 512 models are supported now in LMS 3.0.1 in the content engine packages. The other models like the 612 and NME will not be supported until next year. There is no support in LMS 2.6.
