Webcast-Catalyst9k
ciscoworks-2000
Dear All,
Can any body help me to get the patches for ciscoworks 2000, campus manager 3.1.
At the time of campus manager installation i am getting cannot start crmgtd error. kindly help me for the same.
Thanks & Regards,
Ciscobuddy
Red
Re: ciscoworks-2000
I doubt that installing patches would fix this.
Try opening a DOS shell, cd to CSCOpx\setup\support
Issue the command: resetcasuser
Next, issue the command: net start crmdmgtd
See if that helps.
Re: ciscoworks-2000
hi habib,
Thanks for ur reply, i was trying to do the same thing which u told me but still i am getting error " The password does not meet the password policy requirments. check the minimum password length,password complexity and password history requirments. can u pls tell me about the same.
one more question i am getting error "couldnot stop crmtmgtd" when i was trying to install cd1 patch.
pls help me ASAP
Thanks & Regards,
Ciscobuddy
Red
Re: ciscoworks-2000
Looks like you have some security policy implemented on your server that is forbidding you from successfully installing / running CiscoWorks.
270
