Webcast-Catalyst9k
ciscoworks 3.0 authentication issue
I change authentiction method from local to radius server, but maybe I did not get proper setup.I could not log in anymore even through I use "admin" account. How could I change back local authentiction?
thanks
1 ACCEPTED SOLUTION
Re: ciscoworks 3.0 authentication issue
Shutdown dmgtd, then run the following command:
NMSROOT/bin/perl NMSROOT/bin/ResetLoginModule.pl
Then restart dmgtd, and you will be back to using local authentication.
thanks man. it works
BTW, the path is like that:
CSCOpx\bin\perl CSCOpx\bin\ResetLoginModule.pl
101
