i have just installed CiscoWorks 3.0 and it has problems with performance. The RAM memory raises to the maximum and stays in the maximum all the time (so it makes impossible to navigate in the portal). I have no device added and i have tried to install the dic update 2007 but still the same.
The server is a ProLiant DL360 G5 with 4 gb. of RAM memory and 8 gb. of Swap and windows 2003 SE SPK 2. The installation directory is no the default, but f:/CSCOpx.
The CPU is OK. I have installed Ciscoworks via iLO console.
The "top" processes in memory consumption are:
tomcat (257M), java (88M), sm_server (60M), sm_server (60M), 13 cwjava.exe processes (20-50M each).
Thank you in advanced.
