06-13-2007 11:22 AM
I've just did the fresh install of CiscoWorks LMS25 yesterday on Sol9 and then I was able to login to CiscoWorks using admin login credential. This morning when I installed the patch LSM25_dec2005 and now when I try to login it doesn't like the admin pasword anymore. when I look at the install logs and line where it says
Do you want to see the passwords that were entered/randomly generated and I see the correct password there. but I still get the errr "Authentication failed. Please try again" I'm not using any other login methon on CiscoWorks.
06-20-2007 11:55 AM
You can change your CiscoWorks Admin password by using either the CiscoWorks user password recovery utility or from the GUI, if you want to change it.
06-20-2007 02:08 PM
You can try this:
For Solaris:
-- Stop the Daemon Management process by typing:
#/etc/init.d/dmgtd stop
-- Edit the cwpass password file by copying (and keeing appropriate permissions)the
/opt/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet/orig/cwpass
to
-- Restart all Daemon processes by typing:
# /etc/init.d/dmgtd start
