Community Member
CiscoWorks and Exchange
Mail doesn't go from CW through Exchange to addressee.
Any specific setings on Exchange to adjust ?
CW exists in the Exchange's list of the senders,
may be need to play with sender names.
Are names need to be known by Exchange ?
smtp server and recipients are set up on VMS.
regards,
Alex
Silver
Re: CiscoWorks and Exchange
Exchange usually demands authentication. Ciscoworks doesn't provide any.
You have tell exchange to allow smtp from the Ciscoworks IP.
Cheers,
Michel
Community Member
Hi Michel
>Exchange usually demands authentication. Ciscoworks >doesn't provide any.
how it could be solved ?
>You have tell exchange to allow smtp from the >Ciscoworks IP.
My CW is in the list of allowed IP's on Exchange
regards,
Alex
Silver
Alex,
Sollution is to allow Ciscoworks to do it anonymously.
There is an smtp.log in your \CSCOpx\log directory.
That should contain clues why it's not working.
There is also an executable called blat.exe in \CSCOpx\bin\ that can help you diagnose why it won't work.
Cheers,
Michel
Community Member
Hi Michel,
I'm also facing the same problem, please help me where exactly we need to change the configuration, here is my smtp logs.
[ Sun May 14 10:39:43 GMT+03:00 2006 ] INFO [Util : sendMail] : sendMail() - Starts
[ Sun May 14 10:39:43 GMT+03:00 2006 ] INFO [Util : sendMail] : SMTP Server:10.1.45.110
[ Sun May 14 10:39:43 GMT+03:00 2006 ] INFO [Util : sendMail] : From ID:vernon.williams@aramco.com
[ Sun May 14 10:39:43 GMT+03:00 2006 ] INFO [Util : sendMail] : To ID:vernon.williams@aramco.com
[ Sun May 14 10:39:43 GMT+03:00 2006 ] INFO [Util : sendMail] : Subject: Syslog Force Purge -Server1 test email
[ Sun May 14 10:39:43 GMT+03:00 2006 ] ERROR [Util : sendMail] : Error in connecting the SMTP server [10.1.45.110]
[ Sun May 14 10:39:43 GMT+03:00 2006 ] ERROR [Util : sendMail] : IOException: java.net.SocketException: Software caused connection abort: connect
[ Sun May 14 10:39:43 GMT+03:00 2006 ] ERROR [Util : sendMail] : Software caused connection abort: connect
[ Mon May 15 01:00:01 GMT+03:00 2006 ] INFO [Util : sendMail] : sendMail() - Starts
[ Mon May 15 01:00:01 GMT+03:00 2006 ] INFO [Util : sendMail] : SMTP Server:10.1.45.110
[ Mon May 15 01:00:01 GMT+03:00 2006 ] INFO [Util : sendMail] : From ID:vernon.williams@aramco.com
[ Mon May 15 01:00:01 GMT+03:00 2006 ] INFO [Util : sendMail] : To ID:vernon.williams@aramco.com
[ Mon May 15 01:00:01 GMT+03:00 2006 ] INFO [Util : sendMail] : Subject:Syslog Records - Default purge job
[ Mon May 15 01:00:01 GMT+03:00 2006 ] ERROR [Util : sendMail] : Error in connecting the SMTP server [10.1.45.110]
[ Mon May 15 01:00:01 GMT+03:00 2006 ] ERROR [Util : sendMail] : IOException: java.net.SocketException: Software caused connection abort: connect
[ Mon May 15 01:00:01 GMT+03:00 2006 ] ERROR [Util : sendMail] : Software caused connection abort: connect
[ Mon May 15 03:00:04 GMT+03:00 2006 ] INFO [Util : sendMail] : sendMail() - Starts
[ Mon May 15 03:00:04 GMT+03:00 2006 ] INFO [Util : sendMail] : SMTP Server:10.1.45.110
[ Mon May 15 03:00:04 GMT+03:00 2006 ] INFO [Util : sendMail] : From ID:vernon.williams@aramco.com
[ Mon May 15 03:00:04 GMT+03:00 2006 ] INFO [Util : sendMail] : To ID:vernon.williams@aramco.com
[ Mon May 15 03:00:04 GMT+03:00 2006 ] INFO [Util : sendMail] : Subject:Change Audit Purge Job : ChangeAudit Records - default purge job
[ Mon May 15 03:00:04 GMT+03:00 2006 ] ERROR [Util : sendMail] : Error in connecting the SMTP server [10.1.45.110]
[ Mon May 15 03:00:04 GMT+03:00 2006 ] ERROR [Util : sendMail] : IOException: java.net.SocketException: Software caused connection abort: connect
[ Mon May 15 03:00:04 GMT+03:00 2006 ] ERROR [Util : sendMail] : Software caused connection abort: connect
Thanks in advance.
110
