01-02-2007 01:13 PM
I installed LMS 2.5, with the RME, but not functions SYSLOG. But this collecting LOG's.
Which the solution for this problem?
Solved! Go to Solution.
01-02-2007 01:44 PM
If SyslogAnalyzer is never started, then you will never get any messages processed. SyslogAnalyzer depends on EssMonitor, RMEDbMonitor, CTMJrmServer, and jrm. Check the status of those processes as one of them must not be running correctly.
01-02-2007 01:19 PM
Exactly what aspects of syslog are not working? What syslog messages are appearing in the server's syslog file? What are the statuses of the SyslogCollector and SyslogAnalyzer processes?
01-02-2007 01:35 PM
When I open the RME and I ask for a report of them you finish 24 hours, appears "No records.".
The statuses of the SyslogCollector is "Program started - No mgt msgs received", and of the SyslogAnalyzer is "Never started ", but I initiated these processes manually, but never they change the status.
01-02-2007 01:44 PM
01-02-2007 02:20 PM
They had disappeared "Device Selector", I reboot the server.
01-02-2007 02:55 PM
My friends, very thanks
Tt decided my problem, but this occurs again inside of some days. I have that to carry through this process again? This is normal?
01-02-2007 03:05 PM
To put the conditions of the processes they are:
SyslogAnalyzer Never started
EssMonitor Running normally
RMEDbMonitor Running normally
CTMJrmServer Never started
jrm Waiting to initialize
SyslogCollector Program started - No mgt msgs received
01-02-2007 05:25 PM
The root problem is jrm. What platform are you running on, and did you change the server's hostname after installing LMS?
01-03-2007 08:27 AM
Hi ms. Jclarke,
This functioning in the Intel platform, and I did not modify no user. When you says hostname of the user, which hostname wants to say?
01-03-2007 08:32 AM
I forgot to say in which S.O. this working. In Windows Server 2003 R2
01-03-2007 09:15 AM
I didn't say hostname of the user. I asked about hostname of the server. In any event, the jrm.log should have some errors as to why it is not fully initializing.
