Community Member
CiscoWorks and RME
I installed LMS 2.5, with the RME, but not functions SYSLOG. But this collecting LOG's.
Which the solution for this problem?
1 ACCEPTED SOLUTION
Re: CiscoWorks and RME
If SyslogAnalyzer is never started, then you will never get any messages processed. SyslogAnalyzer depends on EssMonitor, RMEDbMonitor, CTMJrmServer, and jrm. Check the status of those processes as one of them must not be running correctly.
Exactly what aspects of syslog are not working? What syslog messages are appearing in the server's syslog file? What are the statuses of the SyslogCollector and SyslogAnalyzer processes?
Community Member
When I open the RME and I ask for a report of them you finish 24 hours, appears "No records.".
The statuses of the SyslogCollector is "Program started - No mgt msgs received", and of the SyslogAnalyzer is "Never started ", but I initiated these processes manually, but never they change the status.
Community Member
They had disappeared "Device Selector", I reboot the server.
Community Member
My friends, very thanks
Tt decided my problem, but this occurs again inside of some days. I have that to carry through this process again? This is normal?
Community Member
To put the conditions of the processes they are:
SyslogAnalyzer Never started
EssMonitor Running normally
RMEDbMonitor Running normally
CTMJrmServer Never started
jrm Waiting to initialize
SyslogCollector Program started - No mgt msgs received
The root problem is jrm. What platform are you running on, and did you change the server's hostname after installing LMS?
Community Member
Hi ms. Jclarke,
This functioning in the Intel platform, and I did not modify no user. When you says hostname of the user, which hostname wants to say?
Community Member
I forgot to say in which S.O. this working. In Windows Server 2003 R2
I didn't say hostname of the user. I asked about hostname of the server. In any event, the jrm.log should have some errors as to why it is not fully initializing.
250
