09-02-2010 06:00 AM
I want to do the archieve configurations of couple of routers/switches with only ssh/telnet and rest thousands of devices will be via snmp.
Currently I am backing up the configurations of thoudands of routers/switches via snmp, as snmp is configured on them, but couple of routers/switches are external and snmp is not configured on them so I want to get their configuration via ssh/telnet only.
Please advise me that is it possible to do the archieve configurations of routers/switches with only ssh/telnet?
I am using the
LMS: 1.2.0
RME: 4.3.0
CS: 3.3.0
CM: 5.2.1
DFM: 3.2.0
Solved! Go to Solution.
09-02-2010 11:46 PM
The config archive protocol order applies to all devices universally. Since you are using TFTP for most of your devices, I recommend you leave TFTP at the top of the protocol order list. Add TELNET and SSH below TFTP. The external devices will be attempted with SNMP/TFTP, but those operations will fail. RME will then fall back to TELNET then to SSH. It will eventually fetch the configuration successfully.
09-02-2010 11:46 PM
