Community Member
ciscoworks assistant broke!!!
Versions:
LMS 3.2
CIscoworks Assistant 1.2
Windows Server 2008
Problem:
When attempting to configure CiscoWorks Assistant (CWA) for the first time, CiscoWorks Server (CWS) hangs at "collecting existing server information." After error message appears (posted below), CWA configuration fails and I have to restart the whole process over and again in an infinite loop.
Error Output:
CWA0: Could not fetch the error message from the database.
CWA database engine may not be running.
Check if the OpsxmlDbEngine (Common Services > Server > Admin > Processes) is running. If the process is not running, restart the process and please try again.
Fix Actions Taken to This Point:
- Validated services listed in error output were started
- Restarted server
- Restarted CWS
- Attempted uninstall of CWA
     - In order to remove CWA, Common Services also has to be removed along with its dependency.
          - In attempt to uninstall Common Services, error message states all LMS tools requiring Common Services leading to a virtual full uninstall of             CWS
- Attempted to use CWS install disk to reinstall CWA
     - First point of reinstall includes a full backup of existing CWS and settings, which fails each time
- Attempted upgrade of CWA to 1.4
     - Perl file involved does not execute upon invoke via command prompt... just hangs at blinking cursor
Thanks for any and all help!
- Fox
Re: ciscoworks assistant broke!!!
Post the output of the pdshow command as well as the list of contents under NMSROOT/objects/wfengine.
Community Member
Folder Contents:
Objects
Program
dml
Wizard_c.dtd
file
Disk.dll
messagebus
MessageBus.dll
ProcSys.dll
                                                Procsys
        ace.dll
GGPSJ.dll
GGPSjExt.dll
Pbd.exe
pbd.log
PBusExtnDLL.dll
PBusSvc.exe
psBus.jar
xerces-c_2_2_0.dll
                                                Support
                                                Temp Files
                                                ace.dll
Config.dll
Config.pol
DataStore.exe
DMLDLLInterface.dll
DMLEngine.cfg
DMLEngine.dll
DMLFileTags.dll
DMLHttpTags.dll
DMLMath.dll
DMLOutputTags.dll
DMLTags.dll
DMLUtils.dll
GGExtnDll.dll
GGHelper.exe
GGProxy.exe
GGScript.exe
GGShared.dll
GGTime.dll
HTTPClient.dll
libsasl.dll
LicUpdate.exe
MiscTags.dll
MsgTag.dll
OpsBREngine.exe
OpsConfUpdate.exe
OpsRTSvc.exe
OpsXML.ini
OpsXML.log
Product.ini
Provisioneer.cfg
Provisioneer.exe
Start.bat
SvcStop.dll
xerces-c_2_2_0.dll
PDSHOW Output:
Process= UPMDbEngine
State  = Program started - No mgt msgs received
Pid    = 2512
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:47:36 AM
Stop   = Not applicable
Core   = Not applicable
Info   = Application started by administrator request.
Process= UPMDbMonitor
State  = Running normally
Pid    = 3048
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:47:40 AM
Info   = DbMonitor Running Normally.
Process= Tomcat
Pid    = 2636
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:47:43 AM
Process= TomcatMonitor
Pid    = 3368
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:47:47 AM
Info   = Tomcat Server up
Process= Apache
Pid    = 3304
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:49:35 AM
Process= RMEDbEngine
Pid    = 5624
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:49:37 AM
Process= Proxy
Pid    = 5804
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:49:41 AM
Info   = Server started by admin request
Process= ProcSysBus
Pid    = 5816
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:49:43 AM
Process= OpsxmlDbEngine
Pid    = 19372
RC     = 0
Signo  = 0
Start  = 5/26/2010 9:35:37 AM
Process= OpsXMLRuntime
Pid    = 17656
RC     = 0
Signo  = 0
Start  = 5/26/2010 9:35:43 AM
Process= CWAPublisher
State  = Administrator has shut down this server
Pid    = 0
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:49:57 AM
Stop   = 5/25/2010 11:17:47 AM
Process= NameServer
Pid    = 6232
RC     = 0
Signo  = 0
Process= NameServiceMonitor
Pid    = 6360
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:50:01 AM
Info   = NameServer is fully up now !
Process= EDS
Pid    = 6412
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:50:05 AM
Info   = Initialization complete
Process= LicenseServer
Pid    = 6692
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:51:27 AM
Process= IpmDbEngine
Pid    = 6812
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:51:29 AM
Process= INVDbEngine
Pid    = 7048
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:51:35 AM
Process= FHPurgeTask
State  = Transient terminated
Pid    = 0
RC     = 0
Signo  = 0
Start  = 6/1/2010 12:00:00 AM
Stop   = 6/1/2010 12:00:02 AM
Info   = DPS Task FHPurgeTask completed at Tue Jun 01 00:00:01 PDT 2010. For status check Job Browser UI.
Process= FHDbEngine
Pid    = 3216
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:51:41 AM
Process= ESS
Pid    = 5828
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:51:45 AM
Process= EssMonitor
Pid    = 2100
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:51:49 AM
Info   = ESS is fully up now !
Process= EventFramework
Pid    = 6992
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:00 AM
Process= PMServer
Pid    = 6020
RC     = 0
Signo  = 0
Info   = PMServer is up and running
Process= SyslogCollector
Pid    = 7480
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:04 AM
Process= EPMDbEngine
Pid    = 7488
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:06 AM
Process= EPMServer
Pid    = 7752
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:10 AM
Info   = EPMServer is up and running
Process= FHServer
Pid    = 7892
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:14 AM
Info   = FHServer started.
Process= diskWatcher
Pid    = 7900
RC     = 0
Signo  = 0
Info   = diskWatcher initialized OK.
Process= DFMMultiProcLogger
Pid    = 7908
RC     = 0
Signo  = 0
Process= DFMLogServer
Pid    = 7916
RC     = 0
Signo  = 0
Process= DFMCTMStartup
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 5/25/2010 10:54:33 AM
Process= DfmBroker
Pid    = 7948
RC     = 0
Signo  = 0
Process= DfmServer
Pid    = 6940
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:18 AM
Info   = DfmServer initialized OK.
Process= DfmServer1
Pid    = 7712
RC     = 0
Signo  = 0
Info   = DfmServer1 initialized OK.
Process= DCRDevicePoll
Pid    = 0
RC     = 0
Signo  = 0
Start  = 6/1/2010 7:50:08 AM
Stop   = 6/1/2010 7:50:19 AM
Process= CSSCPServer
Pid    = 7720
RC     = 0
Signo  = 0
Process= CSRegistryServer
Pid    = 812
RC     = 0
Signo  = 0
Info   = CSRegistryServer is running in other process
Process= CSDiscovery
State  = Never started
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Info   = Not applicable,
Process= CmfDbEngine
Pid    = 2900
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:21 AM
Process= CmfDbMonitor
Pid    = 8500
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:25 AM
Process= DCRServer
Pid    = 8724
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:26 AM
Info   = DCRServer is up and running
Process= CMFOGSServer
Pid    = 9116
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:38 AM
Process= CampusOGSServer
Pid    = 8356
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:42 AM
Process= EssentialsDM
Pid    = 8364
RC     = 0
Signo  = 0
Info   = RME Device Management started.
Process= ConfigMgmtServer
Pid    = 9244
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:52 AM
Process= ICServer
Pid    = 9260
RC     = 0
Signo  = 0
Info   = ICServer started.
Process= RMEOGSServer
Pid    = 9268
RC     = 0
Signo  = 0
Process= PMCOGSServer
Pid    = 9560
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:52:56 AM
Process= TISServer
Pid    = 9568
RC     = 0
Signo  = 0
Process= DFMOGSServer
Pid    = 10064
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:53:00 AM
Process= InventoryCollector
Pid    = 9692
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:53:04 AM
Info   = InventoryCollector is up and running
Process= Interactor
Pid    = 9336
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:53:08 AM
Process= InventoryCollector1
Pid    = 9500
RC     = 0
Signo  = 0
Process= Interactor1
Pid    = 10544
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:53:12 AM
Process= NOSServer
Pid    = 10552
RC     = 0
Signo  = 0
Info   = NOSServer is up and running
Process= PTMServer
Pid    = 10560
RC     = 0
Signo  = 0
Info   = Started Successfully
Process= UPMProcess
Pid    = 10568
RC     = 0
Signo  = 0
Info   = UPMProcess started successfully.
Process= EDS-GCF
Pid    = 10576
RC     = 0
Signo  = 0
Info   = GCF Initialization complete at Tue May 25 10:54:23 PDT 2010
Process= jrm
Pid    = 10584
RC     = 0
Signo  = 0
Process= 1076
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 1078
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CTMJrmServer
Pid    = 10516
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:54:16 AM
Info   = CTMJrmServer started.
Process= ChangeAudit
Pid    = 12236
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:54:19 AM
Process= SyslogAnalyzer
Pid    = 9688
RC     = 0
Signo  = 0
Process= DataPurge
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 5/25/2010 10:54:52 AM
Info   = DataPurge initialization completed at Tue May 25 10:54:51 PDT 2010.
Process= IPMProcess
Pid    = 10956
RC     = 0
Signo  = 0
Process= IPMOGSServer
Pid    = 8708
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:54:23 AM
Process= ANIDbEngine
Pid    = 11600
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:54:25 AM
Process= ANIServer
State  = Running with busy flag set
Pid    = 12644
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:54:29 AM
Info   = ANIServer started.
Process= UTMajorAcquisition
Pid    = 0
RC     = 0
Signo  = 0
Start  = 6/1/2010 9:24:11 AM
Stop   = 6/1/2010 9:24:41 AM
Process= MACUHIC
Pid    = 12956
RC     = 0
Signo  = 0
Start  = 5/25/2010 10:54:33 AM
Info   = Started.
Process= UTLITE
Pid    = 12964
RC     = 0
Signo  = 0
Info   = Started.
Process= UTManager
Pid    = 12972
RC     = 0
Signo  = 0
Info   = Started.
Process= VNMServer
Pid    = 12980
RC     = 0
Signo  = 0
Process= WlseUHIC
Pid    = 12988
RC     = 0
Signo  = 0
Info   = Started.
Process= AdapterServer1
Pid    = 12996
RC     = 0
Signo  = 0
Pid    = 13004
RC     = 0
Signo  = 0
Assuming that your reinstall steps haven't damaged the OpsXML installation, try reinitializing the opsxml database, then see if CWA works.  To do that, follow the database reinit instructions in https://supportforums.cisco.com/docs/DOC-8796 .  You only need to reinit opsxml.
Community Member
WARNING: Existing contents of opsxml database will be lost.
Do you want to continue [y/n]?y
opsxml Unregistration failed
INFO: Starting the DataBase
    Starting database engine opsxmlEng
INFO: Process created
INFO: Started the Database engine : opsxmlEng Retry 0
INFO: Started the Database engine : opsxmlEng Retry 1
INFO: Started the Database engine : opsxmlEng Retry 2
INFO: Started the Database engine : opsxmlEng Retry 3
INFO: Started the Database engine : opsxmlEng Retry 4
INFO: Started the Database engine : opsxmlEng Retry 5
INFO: Started the Database engine : opsxmlEng Retry 6
INFO: Started the Database engine : opsxmlEng Retry 7
INFO: Started the Database engine : opsxmlEng Retry 8
INFO: Started the Database engine : opsxmlEng Retry 9
INFO: Getting message
INFO: Connect the database dsn=opsxml
INFO: Connected the Database
INFO: Command Executed
INFO: Connecting the Database opsxml
INFO: Company=Cisco Systems;Application=NMTG;Signature=010fa55157edb8e14d818eb4f
e3db41447146f1571g32125eb777a87cbf8b29a954f559d4221b792ff8
INFO: Preparing AUTH cmd
INFO: AUTH Executed
INFO: AUTH cmd finished
INFO: Stopping the Database engine opsxml
    Stopping database engine opsxmlEng
SQL Anywhere Command File Hiding Utility Version 10.0.1.3830
INFO: Database [opsxml] authenticated successfully.
INFO: Calling OpsConfUpdate executable for changing cwa password.
Successfully updated the CWA Engine Configuration file.
INFO: Connect the database DSN=opsxml
INFO: No Record found in CWA_SupportedApps table.
opsxml database initialization failed.
The reinstall never occured. Too many components were required to be uninstalled in order to continue, so reinstall was aborted.
Community Member
With a second attempt, it seems that the script completed successfully. Ciscoworks Assistant is now un-broke!!!
THANK YOU SO MUCH FOR YOUR HELP!!!
-fox
502
