Community Member
CiscoWorks & Cisco 4402/4404 Wireless LAN Controller
I have two WLCs in my network. I can see them in CW, but can't inventory them or archive them with RME. I also don't see where the WLCs are in the CW supported device list. Is this correct?
Re: CiscoWorks & Cisco 4402/4404 Wireless LAN Controller
RME support for WLCs was recently added for RME 4.0.6, 4.1.1, and 4.2. Go to Common Services > Software Center > Device Update, and download and install all available updates for Resource Manager Essentials and Common Services. You will then have WLC support.
Community Member
Thanks Joe. I am running RME 4.1.1. The WLC is a 4402. Your assistance is appreciated.
As I said, download and install the latest RME and Common Services updates, and you will have support for this device.
234
