Webcast-Catalyst9k
CiscoWorks: Compliance check gives errors.
when I try to run compliance job, via RME->Compliance Mgmt->Compliance Check, select the Template and click compliance check, I am getting below error message. Please advise how to resolve this issue.
Problem with File /WEB-INF/screens/config/dcma/BaseLine/BaseLineViewer.jsp!!!null
And when try to run compliance job, via RME->Compliance Mgmt->Compliance Check, select the template and click compliance check, I am getting below error message. Please advise how to resolve this issue.
HTTP Status 500 -
type Exception reportmessage description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.util.NoSuchElementException
java.util.StringTokenizer.nextToken(StringTokenizer.java:332)
com.cisco.nm.rmeng.dcma.ui.helper.BaseLineTableData.setTable(BaseLineTableData.java:89)
com.cisco.nm.rmeng.dcma.ui.action.DCMABaseLineComplianceAction.perform(DCMABaseLineComplianceAction.java:1030)
org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.29 logs.
Thanks. I am using LMS 3.2.1.
217
