Ciscoworks - Could not eneter enable mode
We recently used Ciscoworks to change our enable password on all our managed devices.  Since then it has been unable to archive the configurations.  We have changed the default credentials in Ciscoworks and have confirmed that they are correct by exporting the device, and also manually logging on using the credentials.
The weird thing is, any new devices that we add into ciscoworks are able to have their configs archived.  If we remove a device and add it in again the config archive works.
Any existing device does not get their config archived.
Any thoughts on how we can fix this?  I was thinking just delete everything and import them in again, but I’m not too sure of the process.
Thanks.
1 REPLY
Re: Ciscoworks - Could not eneter enable mode
If you go to RME >  Admin > Config Mgmt > Transport Settings and choose NetConfig as "Application Name", do you have TFTP as the primary  "config deploy" protocol?
197
