CiscoWorks ---Detailed Device View Issue
Hi, I am facing a issue in DDV, I am getting a lot of alerts because admin status is showing "not present" for an interface but the interface is ok on router 3745. Due to this I am getting frequent alerts once for Admin status up and once for admin status notpresent
Please help me....
Everyone's tags (3)
Re: CiscoWorks ---Detailed Device View Issue
Post a walk of the ifTable for this device as well as the specific details of one of these bogus events.
Thanks Joe to hear from you....
Please guide me how do I make ifTable walk, after that I will send you all the details.
Durgesh
You can use the SNMP Walk tool in Device Center to do this.  Just specify a starting OID of "ifTable".
Hi Joe,
I tried doing the same and I also specified the OID. But it gives me the attached result.
Please help
You need to specify a starting OID value of "ifTable" (without quotes).  If you want, the OID to use is .1.3.6.1.2.1.2.2.
Hi Joe,
Yes I tried the same using the OID but the result was same as I attached.
Please confirm me, does a normal computer support snmpwalk command or we need to install any special tool or software to run the snmpwalk command from the CLI of computer.
Post a screenshot of the settings you filled out in the SNMP Walk tool.
675
