09-04-2009 04:59 AM
This should be a simple question for someone. When I unmanage interface or IP address on a device in DFM and apply the changes it appears to work, but then eventually the interface or IP ends back up in a managed state. Almost as if it was rediscovered. Am I missing something?
Solved! Go to Solution.
09-04-2009 08:33 AM
This sounds like bug CSCsz08953. A patch is available from the TAC for DFM 3.1.3.
09-04-2009 08:33 AM
09-04-2009 08:41 AM
That fits. I'll see about getting the patch.
09-30-2009 04:15 AM
Just a question if it this did solved your issue for you?
Have exactly the same problem but the Bux fix recomended in here didnt help me
Thanks in advanced.
09-30-2009 04:20 AM
Yes, it did actually resolve the issue.
