CiscoWorks DFM
This should be a simple question for someone. When I unmanage interface or IP address on a device in DFM and apply the changes it appears to work, but then eventually the interface or IP ends back up in a managed state. Almost as if it was rediscovered. Am I missing something?
1 ACCEPTED SOLUTION
Re: CiscoWorks DFM
This sounds like bug CSCsz08953. A patch is available from the TAC for DFM 3.1.3.
Re: CiscoWorks DFM
Re: CiscoWorks DFM
That fits. I'll see about getting the patch.
Re: CiscoWorks DFM
Just a question if it this did solved your issue for you?
Have exactly the same problem but the Bux fix recomended in here didnt help me
Thanks in advanced.
Re: CiscoWorks DFM
Yes, it did actually resolve the issue.
179
