Ciscoworks Fails to Manage ASA5550-Ver 8.3(1) via SNMPv3
Hello Everyone, I have been trying to configure SNMPv3 on an ASA 5550 with the following but it continue to fail..Need some Help.
Config:
snmp-server group groupv3 v3 priv
snmp-server user userid groupv3 v3 auth md5 password2 priv aes 192 password3
ssh 10.10.10.1 255.255.255.255 inside
Ciscoworks snmp Management to device
Read Username:
userid
Read Auth Password:
password2
Read Auth Protocol:
Read Privacy Password:
password3
Read Privacy Protocol:
Write Username:
userid
Write Auth Password:
password2
Write Auth Protocol:
Write Privacy Password:
password3
Write Privacy Protocol:
Timeout (in seconds):
Test Results
SNMPRv3(Read) Failed
   Sent:5 recvd:0 min:14 max:14 avg:14 timeout:2 min_size: 1472 protocol: snmpv3_get port: 0
SNMPWv3(Write) Failed
   Sent:5 recvd:0 min:0 max:2 avg:2 timeout:2 min_size: 1472 protocol: snmpv3_set port: 0
Re: Ciscoworks Fails to Manage ASA5550-Ver 8.3(1) via SNMPv3
From the screen shot below, i do not see any option selected for Read Auth Protocol and Read Privacy protocol.  Have you checked that? or did screenshot not paste properly with the options ....
you can also check if the passwords are 8 Characters or more.
or try polling with Net-snmp to eliminate application issues.
you can turn on Debug snmp packets and poll the box to see what really is happening.
Yeah the protocol did not get copied, But I will attempt your suggestion and post the outcome asap.
517
