Webcast-Catalyst9k
CiscoWorks: How to login to CiscoWorks via TACACS
How it’s possible that people login to CiscoWorks via TACACS. Also is it possible that local login also remain active.
Is it possible that from CW I can create a access control level that in LEVEL1-Administrators-they can perform any tasks and LEVEL2-Users-can perform any task but unable to add/delete a device in CW.
I am using;
LMS:3.2
RME: 4.3
CM:5.2.1
1 ACCEPTED SOLUTION
Re: CiscoWorks: How to login to CiscoWorks via TACACS
It looks you need to integrate CiscoWorks with ACS and then you can centrally control the uthentication and authorization part directly from ACS for the users in CiscoWork LMS
Kindly have a look at this doc :-
http://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html
Gaganjeet
Gaganjeet
THANKS
498
