Webcast-Catalyst9k
CiscoWorks issue
I started CiscoWorks with CS3.0, RME4.0 and Campus 4.0 on Solaris 9 SUNW,UltraSPARC-II. and then I upgraded all the way to the follwoing
1. CiscoWorks Common Services 3.0.5 17 Nov 2006, 07:41:24 EST
2. CiscoView 6.1.5 17 Nov 2006, 07:41:24 EST
3. Integration Utility 1.6.0 01 Mar 2006, 09:38:09 EST
4. Campus Manager 4.0.6 17 Nov 2006, 07:41:24 EST
5. Resource Manager Essentials 4.0.5 17 Nov 2006, 07:41:24 EST
Yesterday I had issues with CiscoWorks and opened a TAC Case But Engineer called it "unsupported hardware" and recommended that I upgrade to Sun Ultra Sparc IIIi or dual Sun Sparc IIICu before it can be supported by TAC.
When I had upgraded to LMS2.6 (downloadable patch) if didn't say anywhere that a hardware need to upgraded. Can someone guide me here.
1 REPLY
Re: CiscoWorks issue
LMS 2.5+ only supports US III. As of LMS 2.6, we added support for US IV as well. The requirements documentation for the LMS bundle indicates this:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/lms/lms26/lms26qm.htm#wp1028293
The TAC is absolutely correct in what they told you. Running on a US II will give you a really bad LMS experience both in terms of performance and functionality.
101
