CiscoWorks jobs purge
Hi All,
I am trying to do purge the jobs to free up my disk space.
When I do Purge Jobs under RME-->Admin-->System Preference-->Job Purge
It says "Purge Enabled for application InvPoller Starting purge.
Purged Job with ID: 1004
I am selecting the purging days older than 3 days.
Even I am not noticing any kind of disk space free up also.
Can anyone please suggest me how we can free up the disk space?
Thanks in advance :-)
Naidu.
Re: CiscoWorks jobs purge
Check the $NMSRoot\log directory and verify which log files occupy a lot of space. You can configure the logrot utility to rotate (delete the old content from)  the logs.
Also, check $NMSRoot\database\rmeng folder. Usually, SyslogFirst.db, SyslogSecond.db and SyslogThird.db could occupy a lot of space. If this is a case, TAC could provide you a special class file to reduce the size of the databases.
Thanks for your well explaination :-)
I checked the lod directory and found.....
syslog.log is occupied more (10GB)
ConfigMgmtServer.log (44 MB)
NOSServer.log (36 MB)
Remaining all are just in kb's
Can I move the syslog.log to another safe location? If not possible
Can you please tell me how to configure the logrot utility to rotate (delete the old content from)  the logs.
Thanks in advance.
Naidu.
Hi All,
can someone help me plz...
thanks in advance.
Naidu.
You can stop the Syslog on your server and then just remove the syslog.log.
Explanations how to configure logrot you can find at http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_common_services_software/3.2/user/guide/admin.html#wp368424. Started from LMS 3.0 logrot is available in GUI as well under Common Services -> Server -> Admin -> Log Rotation.
388
