Webcast-Catalyst9k
CiscoWorks LMS 2.2
Please i would like to know what have I to know (SNMP, VLANs ...) to can manage a network with CiscoWorks LMS 2.2.
Silver
Re: CiscoWorks LMS 2.2
CiscoWorks LAN Management Solution (LMS) is a suite of powerful management tools that simplify the configuration, administration, monitoring and troubleshooting of Cisco networks. To use LMS you need to have SNMP enabled on the devices. For more information on LMS read http://www.cisco.com/en/US/products/sw/cscowork/ps2425/index.html
Here are the things that you need to know
1) IP address of devices (reachable by ICMP or SNMP)
2) SNMP RO & RW community string
3) Enable CDP on devices (for Campus Manager and ANI discovery to work).
Ciscoworks LMS uses Java application heavily. If your server is a low end machine, you'll probably spend most of the time waiting for the application to load.
Just make sure you get a server that is at least 1.5 times the required hardware specs especially memory.
106
