ciscoworks LMS 2.5 & 3.0
is there a big difference between LMS 2.5 and 3.0? need training to use version 3.0. currently using v.2.5
1 REPLY
Re: ciscoworks LMS 2.5 & 3.0
The homepage is completely different in LMS 3.0, but the underlying application pages and workflows are quite similar. The biggest application change is IPM which was completely re-written in LMS 3.0. If you are comfortable with 2.5, you should be able to pick up 3.0 very quickly.
98
