Ciscoworks LMS 2.6 and Internet Explorer 7.0
When using Internet Explorer 7.0 to access to LMS 2.6.
An error message saying : Certificate Error , is displayed.
how can I fix the problem.
Best Regards.
Mustapha Djamel Eddine YAKHLEF
ENAFOR - Algeria
1 ACCEPTED SOLUTION
Re: Ciscoworks LMS 2.6 and Internet Explorer 7.0
IE 7.0 is not supported with LMS 2.6. IE 7.0 support was not added until LMS 3.0. As for certificate errors, you will generally get some kind of certificate warning with any browser you use since LMS uses self-signed certificates by default. Since these certificates are not signed by a trusted CA, the browser warns you that unless you trust the signer, you should not visit that site. In essence, if you trust yourself, you can disregard the message, and continue on.
Thank you for your advice.
hi,
you can use Netscape Navigator for LMS 2.6
116
