Community Member
CiscoWorks LMS 3.0 - Process Failures
Have anyone had any issues of Ciscoworks LMS processes stopping. . I've installed the application several times, with the issue still happening. I've had to create a bat file to manually stop and start the services for LMS.
Re: CiscoWorks LMS 3.0 - Process Failures
Are all of the processes stopping or specific ones? If specific, which ones?
Community Member
Thanks for the response, 80% of the processes are stopping when the issue occurs. Based on the "ProcessState" is shows Administrator has shutdown this server. The list of processes are attached.
What is the OS Version? If this is Windows, which of the CiscoWorks processes are set to automatic vs manual in the services?
Community Member
The OS ver: MS Windows Server 2003 Enterprise edition SP2: Hardware Spec's: (4) 3.80 GHz Xeon CPU's (3.5 Gig of RAM)
Not sure how to verify the auto vs manual in the services setup..I don't recall that step in the documentation during the application install. Can you advise me on how to check??
This would be in Contol Panel - Admin Tools - Services
Community Member
Your right..duh!! Checking the relevant services setup now. Thanks for the help
Community Member
Several services were configured for Manual as the startup type relating to CiscoWorks LMS. I will monitor for another 24 hrs.. To see if the problem clears.
Community Member
Unfotunately the problem has not went away, 72 processes were running sucessfully. 33 were shutdown/stopped at the same time 12/11/08 1:10-1:15 am. Has anyone came across this issue i CW LMS 3.0 or CW LMS 3.0 Dec 2007 Patch.
248
