06-29-2009 03:09 PM
brand new install on Win2k3. I am getting these errors about every 2 days in windows event viewer. I am forced to restart the ciscoworks services every time. I see other Apache issues in the forum. Is this a known issue and fixed in v3.2? thanks.
Faulting application Apache.exe, version 0.0.0.0, faulting module ApacheCore.dll, version 0.0.0.0, fault address 0x00048159.
Apache.exe child process caused an exception and reported error.
06-29-2009 03:12 PM
Yes, this issue is fixed in LMS 3.2.
06-29-2009 03:26 PM
thanks for the quick response.
another quick question. I can't launch any of the Nexus devices in Ciscoview. the error Message
"Cannot find applicable device package for 10.170.112.19.
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component."
I check software update for ciscoview and there isn't any. I am also able to SNMP walk the device from ciscoworks.
06-29-2009 04:40 PM
No, there is no CiscoView support for Nexus. Nexus support is available in RME, Campus, and DFM only.
