12-01-2009 05:13 AM
we've just installed the new version of the LMS 3.2 on a Windows Server 2008 Enterprise SP2. The installation went fine but if we try to launch the CiscoWorks server/application, the Firefox (or IE) web browser can't find the page.
After some investigations, we found that the main daemon didn't start. We tried to launch the service manually but we got an error message (see in attachement). If we launch manually all the other services, we got the authentication page but no redirection is possible and we can't get access to the application. It is impossible to launch the main ciscoworks service and we don't know why !
I hope someone can help us because we have no more idea ...
Thanks in advance
12-01-2009 09:45 AM
You need to manually configure swap space on Windows 2008 for LMS to start. To do this, go to the System Control panel, and configure at least 2048 MB of swap with a max that meets the recommended swap size for the number of devices you will be managing. After doing that, reboot, and Daemon Manager will start.
12-01-2009 10:19 AM
You're my HERO !
It works !
thanks a lot !
12-01-2009 10:47 AM
So LMS 3.2 could work on SP2?
12-01-2009 10:51 AM
Sorry, I missed that point. You're right in that SP2 is not supported, and you will not be able to get TAC support should you run into further problems with LMS.
12-01-2009 10:58 AM
mmmm
yes indeed I can see the authentication page but after the authentication, the page cannot be well redirected ...
Can this problem come from the fact I run the SP2 ?
12-01-2009 11:01 AM
I can be, yes. It may also be simply CSCtb17186.
12-03-2009 07:42 AM
Hello
2008-SP2 is supported since some weeks
/thomas
12-03-2009 09:52 AM
Yes, it looks like they silently announced Windows 2008 SP2 support along with the VMWare 4.0 support about a month ago.
01-20-2010 10:34 AM
I had the same poblem as Nicolas with a Windows 2008 Server SP2 in a VMWare machine; once I fixed the swap memory problem, I neither can start the Daemon service (I attached a screen shot with the error). In the syslog of the application it shows the following message:
Jan 20 19:22:31 127.0.0.1 dmgtd: Http is the port in ssl.properties file and apacheflags to be set is -d D:\CISCOW~1\MDC\Apache
Jan 20 19:22:31 127.0.0.1 dmgtd: PX_PROTOCOL in registry http
Jan 20 19:22:31 127.0.0.1 dmgtd: Apache Args in registry -d D:\CISCOW~1\MDC\Apache
Jan 20 19:22:31 127.0.0.1 dmgtd: PX_PROTOCOL in md.properties file is http
Jan 20 19:22:31 127.0.0.1 dmgt[3008]: 2507(W):Daemon manager anonymous user has not been set up: 00000569
Any idea how I can fix it?
Thanks in advanced!
Laura
01-23-2010 10:11 AM
Start a new thread for your issue.
