PRIMARY RUNNING Config fetch failed for M1978NMS5-11 Cause: Couldnot enter ENABLE Mode from USER Mode
I can putty into the device via SSH and have no problem with my credentials. I went to Common Services > Device and Credentials > Device Management, select this device, and click Edit Credentials. Re-entered the correct enable password multiple times with the same result.
I also tried enabling ArchiveMgmt Service debugging under RME > Admin > System Preferences > Application Loglevel Settings, re-ran the sync archive, then copied some stats from the dcmaservice.log Document attached.
I do not believe that this issue is related to the CSCsu21040 Bug due to the fact I can putty in properly with the correct username/password promts.
Any ideas or suggestions?
