CiscoWorks LMS 4.0 - Discovery doesn't start - HTTP Error 500
Hello
I have LMS installed for one year in my network (about 200 equipments). Recently, I needed to Start a new discovery, but I had this error:
"com.cisco.nm.csdiscovery.CSDiscoveryException: Exception in reading CSDiscovery-config.xml.  Reason :Parsing Error : The element type "MACADDRESS" must be terminated by the matching end-tag "</MACADDRESS>""
I have searched for a missing </MACADDRESS> balise in any "CSDiscovery-config.xml" file I've found on the server but Not found?.
Have you got an idea about this error? Which "CSDiscovery-config.xml" does the server talk about? in which directory?
Thx for any help!
It should be in NMSRoot\conf\csdiscovery\CSDiscovery-config.xml
Do you see the tag in that file?
Hello David,
I've had already found that file but effectively the tag is in that file, and well "terminated" by the corresponding tag, so I don't really understand the error message. Here's an extract:
Any idea?
343
