Community Member
CiscoWorks LMS / ActiveDirectory authentication
LMS 2.6
CiscoWorks Common Services 3.0.5
Campus Manager 4.0.9
CiscoView 6.1.5
Device Fault Manager 2.0.9
Internetwork Performance Monitor 2.6.0
Integration Utility 1.6.0
Resource Manager Essentials 4.0.5
Selected Login Module: MS Active Directory
Server: ldap://server.company.com
Usersroot: ou=Technical Services, ou=Information Technology, dc=company, dc=com
Prefix: cn=
Users created in AD with a first name and last name have a "cn=first<space>last" and the actual logon credentials are stored in "sAMAccountName=loginID". This presents a problem when a LDAP querry is passed from CiscoWorks LMS. When attempting to authenticate CiscoWorks LMS users against Microsoft Active Directory / LDAP, login credentials must be "first<space>last" rather than actual loginID. Desired configuration would be to reference SAMAccountName (loginID) rather than CN. I see CCO references to SAMAccountName under Unified Messaging and NAC documentation. But nothing under CiscoWorks documentation. Is this possible?
Re: CiscoWorks LMS / ActiveDirectory authentication
If I understand you correctly, why not change the prefix from cn= to SAMAccountName= ?
Community Member
You understand correctly. Though I tried changing the prefix to sAMAccountName= and it doesn't work.
Do you have anonymous bind enabled on the AD server? That is required to use SAMAccountName.
Community Member
Nope, anonymous bind is not enabled. That's the source of my problem. Unfortunately, policy won't permit me to enable it either. I guess ACS appliance is the longer-term fix. In the meantime, I can change the user requiring this access. Thanks for your assistance.
1193
