Ciscoworks LMS Question
I need an event viewer for ciscoworks. just one console to look at HUM, DFM notifications and alerts. I dont want to browse mutiple windows to find something
Is there anything out there?
1 REPLY
Bronze
Re: Ciscoworks LMS Question
WIth LMS 3.0 you can create a custom Portal to view your desired views. Very powerfull and usefull for a NOC environment. You can choose from your view from all the LMS modules and put them in one View/Portal.
120
