Community Member
CiscoWorks Management-IP
In my devices I've two Loopback-IPs configured.
For example:
loopback 0
ip address 1.1.1.1 255.255.255.255
loopback 1
ip address 2.2.2.2 255.255.255.255
Is it possible to define in CW that the IP from loopback 0 is the Management-IP.
In the Discovery-Settings I only can say under "Preferred Management IP" -> "Use LoopBack Address"
But I want the Loopback0 as Management-IP not Loopback1
Re: CiscoWorks Management-IP
The discovery algorithm is set to choose the highest loopback address. So if you want to have loopback 0 as the management IP, you need to assign a higher IP to it. See this discovery DOC which has very detailed explanations.
Highlighted
Community Member
Thanks for your answer!
It is not possible to change the IPs but now I know how it works.
I will try a workaround over the nameresolution.
377
