Community Member
CISCOWORKS MASS CONFIG
Hey guys! Need help!
We acquired Ciscoworks LMS 3.1 and I can't seem to find the info I need to use it properly for scripting.
I need to mass configure over 150 2960 switches with a conditional statement, and don't know how or where and in what language to tell Ciscoworks to do that.
Basically I want to script something that would sound like this:
-Check each switch port, one at a time
-If the vlan is X, or Y or Z then
-Write all these interface commands
-Else write all those OTHER interface commands and check the next port!
Anyone can tell me how to do that!?
Thanx,
WANimal
Re: CISCOWORKS MASS CONFIG
This is best done with the baseline compliance feature of RME's Config Archive system. Checkout this whitepaper:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2073/prod_white_paper0900aecd8068cc98.pdf
Then look at these case studies:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/white_paper_c11-529569.html#wp9000239
I think what you want is covered by scenario 4b.
However, since you have an ELSE, you will need to create two different templates to accomplish what you want due to bug CSCtb42198.
Community Member
Thank you my friend (jclarke)...
This at least definitely gives me an idea WHERE to look.
WANimal
Community Member
One problem I encounter in case 4B is that it goes as deep as the interface to check compliance...but I need to go in a VLAN submode to check for compliance, as the compliance must run against the VLAN.
How do I get it down one level to check the VLAN's value??? And can it check with an OR or an AND statement between statements???
As in:
-Check every interface in turn
-Check VLAN value for this interface
-If value is X OR Y or Z
-Then input THESE interface commands
-Else input THOSE interface commands
WANimal
Your template would need a prereq/parent:
Commandlet CheckVlan
IsPrereq: YES
Submode: interface [#.*Ethernet.*#]
Body:
+ switchport access vlan [#(X|Y|Z)#]
Commandlet: DeployCommands
Parent: CheckVlan
Body:
+ command1
+ command2
Then, your other template would look like:
IsPrereq: YES
Body:
+ switchport access vlan [#!(X|Y|Z)#]
Parent: CheckVlan
Body:
+ command1
+ command2
Community Member
Thank you SIR! Kindly!
You're a savior!
I should be able to fix the rest from hereon end!!!
WANimal
316
