Webcast-Catalyst9k
CiscoWorks Monitoring at High Level
I have 2 questions.
1) Is Ciscoworks LMS 3.2 able to display status of all the switches under a stack beside seeing the bayface view using Cisco View.
2) From the CM, I am able to create group. However, is it possible to see the network topology view of how each group is connected to each other and if there's an alarm for a switch under the group, you can see perhaps a red colour group icon.
1 REPLY
Re: CiscoWorks Monitoring at High Level
1. Yes, LMS (DFM) can report traps about stack status from the CISCO-STACKWISE-MIB.  RME's detailed device and chassis reports can show the
separate chassis in a stack.
2. No, the groups are not linked in the topology view.  You can view groups as clouds, but there are no interconnections shown.  The events are not perpetuated to the clouds.
198
