Community Member
Ciscoworks Netconfig
I keep getting the following message
Error occured while processing Possible Cause: Failed to Connect to JRM
I have tried to restart the Ciscoworks server, JRM and CTJRMserver but none have helped
I am trying to run a netconfig job
Re: Ciscoworks Netconfig
Please post the output of the pdshow command. What version of LMS is this? Was the hostname changed on this server recently?
Community Member
LMS 2.6
Hostname was not changed recently
I have attached the pshow output
Please post the output of the command:
pdreg -l CTMJrmServer
The output of the DOS SET command, and the CTMJrmServer.log.
Community Member
D:\CSCOpx\bin>pdreg -l CTMJrmServer
Process = CTMJrmServer
Path = D:\CSCOpx\bin\cwjava.exe
Flags = -cw D:\CSCOpx -cw:jre lib/jre -cp:p MDC/tomcat/webapps/rm
e/WEB-INF/classes,MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar,MDC/tomcat/webapps/
rme/WEB-INF/lib/log4j.jar com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServ
er i5981psp50
Startup = Started automatically at boot.
Dependencies = RMEDbMonitor jrm TomcatMonitor RMECSTMServer
You did not provide the SET output. Also, is this server integrated with ACS?
Community Member
Yes the server is integrated with ACS
AdminEmail=jmacchi@sears.ca
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\tcomadmin\Application Data
CLIENTNAME=LL3LA689
ClusterLog=C:\WINDOWS\Cluster\cluster.log
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=I5981PSP50
ComSpec=C:\WINDOWS\system32\cmd.exe
CWMIBDIR=D:\CSCOpx\objects\share\mibs
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\tcomadmin
LM_LICENSE_FILE=D:\CSCOpx\objects\smarts\conf\trial.dat.DFM
LOGONSERVER=\\I5981PSP50
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=D:\CSCOpx\MDC\tomcat\bin;D:\CSCOpx\objects\smarts\lib;D:\CSCOpx\objects\smarts\bin;D:\CSCOpx\campus\bin;D:\CSCOpx\MDC\Apache;D:\CSCOpx\MDC\jre\bin;D:\CSCOpx\MDC\bin;D:\CSCOpx\lib\jre\bin\server;D:\CSCOpx\objects\db\win32;D:\CSCOpx\bin;C:\Program Files\Support Tools\;C:\Program Files\Windows Resource Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Intel\DMIX;C:\Program Files\IBM\Director\bin;;C:\PROGRA~1\F-Secure\Ssh;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0209
PROMPT=$P$G
SESSIONNAME=RDP-Tcp#4
SM_BROKER=i5981psp50:9002
SM_HOME=D:\CSCOpx\objects\smarts
SM_RULESET_PATH=D:\CSCOpx\objects\smarts\rules
SM_SITEMOD=D:\CSCOpx\objects\smarts\local;D:\CSCOpx\objects\smarts
SM_SNMP_BUG_COMPATIBLE=1
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Temp\2
TMP=C:\Temp\2
USERDOMAIN=I5981PSP50
USERNAME=tcomadmin
USERPROFILE=C:\Documents and Settings\tcomadmin
windir=C:\WINDOWS
Please post the NMSROOT/lib/classpath/jrmuser.properties file.
Community Member
I have attached the file
Okay, there must be a problem with your System Identity User, lms26. How is this user defined in ACS?
Community Member
it is set as omnipotent and SuperLMS under the CiscoWorks components (Ciscoview, RME etc)
why would that affect JRM?
The System Identity User is used for interprocess communication. If it is not defined properly, this type of error can occur. Please post the jrm.log.
Community Member
the file is too large to attach (13 meg)
is there a statement i can look for in the file itself?
Please compress the file, and post it. It's all text, so it should compress well.
Community Member
here is the jrm.log
As I suspected, your System Identity User configuration is not correct. The lms26 user is not being properly authorized by ACS. Recheck your ACS configuration for this user, and make sure it still has all access to all LMS tasks for all devices in LMS.
Community Member
I checked my ACS config
lms26 is there and has Omnipotent access for all CiscoWorks apps
I receive this error when i try to access netconfig under RME
Error occured while processing.
Possible Cause: URN_NOT_FOUND : urn "JRM" : Not found !!
I dont believe this is due to my ACS setup does it?
Yes, it is. Check your Failed attempts log in ACS to see if there are any relevant errors. The jrm.log points to an ACS integration problem with the lms26 user.
You might also try re-entering the lms26 user's credentials under Common Services > Server > Security > System Identity Setup.
Community Member
I tried what was documented but still get the same error - do i have to restart any servers/services?
If not can I just create a new one or change the System Identity and how do I do so?
You can try restarting CiscoWorks Daemon Manager.
Community Member
After the restart its working
Thank you for your help, much appreciated
249
