Ciscoworks notifications and alerts
Is it possible to setup Ciscoworks so that it alerts you when catalyst switches and routers generate excessive port errors? If so, how do I go about setting it up? Thanks.
1 REPLY
Re: Ciscoworks notifications and alerts
In DFM go to Notification Services/Event Sets and check the box beside "HighErrorRate". This will trigger an event notification if a notification group is set up and configured with the corresponding event set. Of course to receive an e-mail notification the e-mail notification group needs to be created.
Hope this helps.
115
