09-29-2007 11:11 AM
are anyone running ciscoworks on T2000, does anyone run it whit logical domains ?
Best regards Martin
09-29-2007 12:07 PM
Hi Martin,
I'm not too sure about the "logical domains" question, but judging by the documentation, it does look like the Sun T2000 is supported as you can see here:
(see table 1)
HTH,
-J
09-29-2007 10:56 PM
The SunFire T2000 (US T1 CPU) is supported by LMS 3.0 and higher only. Domains and Solaris zones are not yet supported by LMS.
I have not seen any service requests from customers running LMS 3.0 on a US T1 yet, but it was tested, and it does work.
09-30-2007 11:52 AM
Ok, Do you know if there are any plans to try it in ldoms or zones ?
09-30-2007 12:35 PM
Yes. This as well as VMWare support for x86 is on the roadmap.
