Community Member
Ciscoworks Physical Discrepancy and 800 Series routers
We have a lot of 83x routers at our sites that use IPSec over DSL to connect back to the corporate office. However now that we have CiscoWorks monitoring these sites I have 60+ discrepancies due to the fact that CDP is running on the internet ethernet interface inside of the router and not on the switchports. So the router is advertising to that it is using 10M connection while the 10/100 switch it is connected to is running at 100M causing the bogus reports. Is there a way in the 83x routers to have CDP run on the switch that is also part of the router? or a way to get rid of the discrepancies?
Re: Ciscoworks Physical Discrepancy and 800 Series routers
It sounds like CDP is already running on the ports connected to the switch. Without it, Campus would not know that the 830 router is connected to the 10/100 switchport to begin with.
This discrepancy could be caused by a bug in the device instrumentation on the router isde (assuming the port really is operating at 100MB). What is the ifSpeed for the port on the 830 that connects to the switch?
Community Member
The 83x is apparently built funny. It has the ADSL/Ethernet WAN connection which apparently connects to the routing processor and from the routing proccessor it has an ethernet connection to the internal 4 port (externally accessible) switch. CDP apparently runs on the routing processor and the internal switch doesn't have CDP or it isn't enabled. The internal switch is 100M while the RP to that switch is 10M. So when I have an AP or another cisco switch plugged into the 83x I get discrepancy errors because the routr things the other device is plugged into the internal ethernet port. Here is some output to show that it is what it thinks:
ATM0 unassigned YES NVRAM up up
BVI1 x.x.x.x YES NVRAM up up
Ethernet0 y.y.y.y YES NVRAM up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset administratively down down
FastEthernet3 unassigned YES unset administratively down down
FastEthernet4 unassigned YES unset administratively down down
NewBernHospice#show cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
NCCoastalCarolina_SW01
Eth 0 121 S I WS-C2950-2Fas 0/24
Note that the local pinterface is Eth 0 and not FA1
That makes things much clearer. There is no way currently to get rid of these discrepancies other than disabling the entire speed mismatch discrepancy under Campus Manager > Admin > Network Discrepancies. The next release of Campus Manager will offer a way to clear individual discrepancies such as this.
Community Member
3.0 of LMS? or next release withing the 2.x scope?
and is there a way to make CDP run on the switching processor on the 83x?
114
